Hi
would be great to have the Expert Setting "LockDirectoriesDuringSync" not only as a global Setting, instead have it as a sync Setting (perfect would be as a "local Setting").
To "move" some data to an "write once" target. There will be problems when the lock mechanism is used, because the lock-File can't be changed/deleted.
For all other data the lock mechanism should be used, that's why the global Setting is a problem.
Regards
Michael
[Feature Request] LockDirectoriesDuringSync as individual setting
