RFS was running just fine for several hours (2 different RFS batch jobs running) But then suddenly one of the the RFS stopped syncing.
I deliberately would change a file in the source directory and see if any of the destination directories would update. no success.
I then open the batch job in FFS and run a "compare" operation and the source change is detected. So manually scanning via FFS works. But the automated RFS just suddenly stopped attempting to sync.
I tried to restart RFS and FFS .exes without success.
There are no errors logged.
Any windows services or special programs required to make FFS RFS work properly?
It makes no sense, please help.
edit: question: where are the logs that log when RFC scans for detected folder changes?
Win 8.1 64 bit, .NET 4.7.0 intel i5 3230m, 12GB ram, SSD drive.
No antivirus program. Just windows firewall + WFC
realfilesync fails after running some time
