realtimesync always rescan bomplete folders.
pixiesfr
I try realtimesync to sync my server with a NAs in realtime.
I created my batch file, and make a sync..
When I use realtime sync, when i make a change on a folder ( add a files , or remove) , realltimesync detect it, but it rescanning throught FFS all the files.
why it like that ?
Thank you for you support.
The only thing RealTimeSync (RTS) does (upon detection of one or more files having been changed), is to launch the specified application, in this case a FreeFileSync (FFS) sync job.
The FFS sync job will simply scan all folders/files in the left-right base location pair(s) tree(s), as defined for that FFS-job.
If your FFS sync definition involves scanning a problematically big amount of files, you might consider to split your FFS sync job in multiple jobs, each covering a coherent, smaller amount of files/folders, and each launched by its own corresponding RTS task, monitoring only the folder(s) relevant for the specific FFS job it will launch.
pixiesfr
Thank you for your explanation
