Add more examples to help
huuurz
in https://freefilesync.org/manual.php?topic=exclude-items please add more examples to make it clearer.
If I want to exclude something via rightclick on the bottom left, the menu often offers something like
\myfolder\
*\myfolder\
and you don't know what the difference is.
So please add
All folders named "SubFolder" below base directory            *\SubFolder\
directly under
Single folder C:\Source\SubFolder                              \SubFolder\
Also please add, what asterisk at the end means (not sure if the following is correct).
So
*\SubFolder\   ===   *\SubFolder\*
but why do I need a trailing asterisk in the example
*temp*
What about foldernames that have dots?
\SubFolder\*.tmp
also matches the files located under
C:\SubFolder\test.tmp\examplefile.txt
So from the help
*.txt files located in subdirectories of base directories     \*\*.txt
should actually analouge to the third line in help be
All files (and folders) ending with ".txt" located in subdirectories of base directories     \*\*.txt
It's just a bit confusing, I think the help could need some more examples.
Thanks and best regards,
huuurz
gogreen1
These suggestions would be helpful. One critical error I've noticed in a lot of user manuals is that they assume users know much more than they actually do know.
