I'm trying to do a mirror from c:\users\guy to \\server\bup\guy. I'm using FFS 9.9 (Donation version) and Windows 7 (both machines). I filtered the appdata folder, which was the only folder contents it showed in the comparison.
I originally copied all the files from the source folder to the destination folder manually, and then I created a Test.txt file in the source only (c:\users\guy).
When I do a compare, nothing shows up in either column.
What am I doing wrong?
Can't get it to work
