LIBSSH2_ERROR_TIMEOUT 15 seconds timeout [libssh2_sftp_write]
Hello, im messing around with this error in regular intervals. Is there a way to increase the time before the timeout happens or a fix in general?
A 15 seconds timeout is not an error in your scenario? (Is such a high-latency connection useable at all?)
Normally the latency is about 20 milliseconds but sometimes my VPN connection abort. Then it takes a while to get reconnected automatically. It would be good if FreeFileSync keep transfering once the VPN connection is established again.
FFS already has "retry on failure". Regarding a "continue file copy after connection abort", I have doubts if this is a safe operation or if it might lead to intermittent data corruption.
It isn't a problem if the whole file has to send again. For me it is only important that the synchronization continues again after the connection is established. Do you mean "automatic retry" or is "retry on failure" another function?
Yes, "automatic retry" with a delay will work the same way a manual retry does.
