"Cannot find the following folders"
Zig
I am synchronizing several folders from my windows 10 pro computer to an external USB drive (H:), Directly connected to my computer through a rear USB 3 port. This is set to happen overnight, when the computer is in sleep mode. I have added a scheduled task to wake the computer 1 minute before the script is to run, in case the computer fails to wake from sleep to run the script on its own.
When I run the script manually, everything works fine; but when I attempt to do it on a scheduled overnight basis the program seems to not "see" the external hard drive, resulting in the following error message:
[3:00:30 AM]  Error:  Cannot find the following folders:
                      H:\Digital Books Backup
                      H:\Downloads Backup
                      H:\Files Backup
                      H:\Firefox Profile Backup
                      H:\Medical Papers Backup
                      H:\Misc Files Backup\Graphics
                      H:\Music Backup
                      H:\My Documents Backup
                      H:\Pictures Backup
                      H:\Quicken Backup
                      H:\Thunderbird Mail Backup
                      If this error is ignored the folders will be considered empty. Missing folders are created automatically when needed.
                      Timeout while searching for folder "H:\Digital Books Backup".
                      Timeout while searching for folder "H:\Downloads Backup".
                      Timeout while searching for folder "H:\Files Backup".
                      Timeout while searching for folder "H:\Firefox Profile Backup".
                      Timeout while searching for folder "H:\Medical Papers Backup".
                      Timeout while searching for folder "H:\Misc Files Backup\Graphics".
                      Timeout while searching for folder "H:\Music Backup".
                      Timeout while searching for folder "H:\My Documents Backup".
                      Timeout while searching for folder "H:\Pictures Backup".
                      Timeout while searching for folder "H:\Quicken Backup".
                      Timeout while searching for folder "H:\Thunderbird Mail Backup".
[3:01:08 AM]  Info:  Comparison finished: 535,548 items found
[3:01:09 AM]  Info:  Synchronizing folder pair: Update>
                         C:\Users\Bill\AppData\Roaming\Mozilla\Firefox\Profiles\15l06nsd.default
[3:01:09 AM]  Serious Error:  Target folder "H:\Firefox Profile Backup" already existing.
(and so forth)
I am not clear if this is a problem related to USB 3 connection as opposed to USB 2 connection or what.
Any help would be appreciated.
Thanks in advance,
Zig
If the issue really *is* a timeout, then increasing "FolderAccessTimeout" will help (https://freefilesync.org/manual.php?topic=expert-settings) or simply "retry on error" once with a sufficient delay.
