Hi
I'm using MacOS High Sierra,
I have set up the following realfilesync but is not woking. What's wrong with my setting?
Cheers
Ronald
RealtimeSync not work
Win 7 x64, RealtimeSync 9.9 not work too but partially.
On system disk C not work, on other disks work. Timeout=10, file system for disks - NTFS.
Executed under user and administrator, but no results.
What's problem?
How RealtimeSync handling received event from OS about changes on disk?
And what is this event?
What's problem?
Oh my god, for system disk C idle setting for 10+ sec too much, need reduce to 1+ sec, otherwise auto sync not run))) very nice ...
Solution: if auto sync not run - reduce idle setting until sync work
Minimal idle = 2 seconds, at which synchronization begins. Every 2 seconds fuck the disks is not an option. I deselected the checkbox auto-close from results-window and now close window with different periodicity manually, thereby allowing run the next iteration. But this is all no auto-synchronization ...
Max idle = 300 seconds, at which synchronization begins.
Summary: idle time [2;300], at which synchronization begins.
Your command line is incorrect. FreeFileSync.app is just a folder and cannot be executed from command line. To get the correct command line just import a .ffs_batch file into RealTimeSync.Hi
I have set up the following realfilesync but is not woking. What's wrong with my setting? rylchen, 23 Apr 2018, 08:21
For the record, the correct path to the FreeFileSync executable in your case is:
/Applications/FreeFileSync_9/FreeFileSync.app/Contents/MacOS/FreeFileSync
