I'm really new to this program, so I'm sorry if this is a noob question.
I'm comparing folders from a local disk and a FTP server. The local server should be mirrored. Once it finds a file on the server side, which isn't on the local side, it should move it to a nwely created folder, called archive.
Example:
Before:
local -->> server
FileX
after:
local -->> server
\archive\FileX
I've tried versioning with these macros, %folder_path2%\archive\%item_path2%. That din't work, though.
Any ideas would be much appriated.
Thanks in advance.
move file to archive folder
Just enter the full FTP path to "archive" where you want the file to be moved to. Copy and paste the FTP path from the main dialog to the versioning folder input field on the screenshot and use the cloud folder picker.
