Realtime Sync Documentation
huuurz
Here it says
RealTimeSync is not required to start FreeFileSync. It can also be used in other scenarios, like sending an email whenever a certain directory is modified.
but I think what was meant is
RealTimeSync does not require to start FreeFileSync. It can also be used in other scenarios, like sending an email whenever a certain directory is modified.
Right? Or did I miss the meaning?
First quote is "You can use FFS standalone" (which we all know)
second quote is "You can use RTS standalone/for other purposes than starting a FFS batch job"
Good catch! Thanks, fixed!
huuurz
Thanks for the fix, I hope it was helpful and not too picky :-)
(can be closed)
