Too good to be true / No FTP support
pascal737
FFS looks very good and I really thought I had discovered the best sync software to replace our actual SyncBackPro. Unfortunately FTP is not supported :-(
Anyone knows another software as great as FFS but which support the most common way to upload files on a server... FTP ?
FFS does not support directly accessing FTP volumes.
However, indirectly it does, by mapping a FTP web space to a drive letter.
See the FFS Help-file.
pascal737
Thanks Plerry for your answer. However this starts to sound to technical to be an easy and stable solution. If we need to begin doing handwork here and there to be able to use the soft... better chose another one.
I mean I do not understand why such a good soft like FFS support SFTP but not FTP ? FTP is everywhere, but not SFTP.
Therefore my very first question, anyone knows another software as great and simple as FFS but which support the most common way to upload files on a server... FTP ?
