Plex
Crivens
Ok, so I've got RTS to work as I want (auto running silently once an hour) with a secondary drive as a mirror to my main media drive that I use for Plex.
However, I also have Plex auto scanning to update the library. I'm pretty happy with manually telling Plex to update it's libraries, but it would be nice to have it update when RTS detects changes and updates the mirrored drive. ie. reducing 2 scans to just 1.
So, is it possible to create a command that makes RTS request a Plex library update? But only when RTS detects a change to the main drive?
Ok, so I've got RTS to work as I want (auto running silently once an hour) Crivens, 12 Jun 2018, 10:00
Are you confusing RTS and FFS? RTS cannot be set up to trigger a sync at specific intervals (at least currently).
So, is it possible to create a command that makes RTS request a Plex library update? But only when RTS detects a change to the main drive? Crivens, 12 Jun 2018, 10:00
Sounds exactly like what RTS is supposed to be doing.
