V10.1 missing files that need to be synced
Granby
Hi
I just upgraded to V10.1 having been using FFS on several machine for several years (and also paid a donation!).
I am now regretting the upgrade because FFS is missing new files added on either side of the comparison. Worked fine with my v. old version (sorry I can't remember what I had before upgrading).
Running Windows 7, and syncing to a Netgear NAS. FFS is missing new or changed files on both sides.
Any suggestions would be welcome.
Before this happened I was a great fan of FFS!
Granby
Many thanks, I had checked the filters in each pairing, and I had thought I had checked the filters in the menu Actions | Sync Settings. However clearly I had not checked the most obvious one behind the main filter icon!
Obvioulsy the upgrade had removed the * from the 'include' so it was doing nothing. And there was me thinking that it was quick because it was the latest version : - ) It was quick because it was doing nothing!
Many thanks.
Granby
Obvioulsy the upgrade had removed the * from the 'include' so it was doing nothing. Granby, 06 Jul 2018, 20:03
What FFS version were you upgrading from? I'd like to check that there isn't any issue with the configuration migration code.
