Hi, I use Windows 7 with FreeFileSync 7.4.
I have a Windows Task, where i call FreeFileSync with a batch-File.
There i will sync some folders. But at the actual version the task will be processed at the windows foreground. At a older version it was processed at the windows background. Only a icon at the system tray was visible
So how can i run the sync-task at windows background?
Sync-Task over Windows-Task is no more at the windows background
Did you configure your batch task to run minimized?
