I recently upgraded from Windows 7 Pro to Windows 10 Pro. I had a shortcut running in the Startup folder to allow RealTimeSync to run at start up. Worked fine on Windwos 7 Pro. However after upgrading unable to have this start automatically. I even tried to make a scheduled task with no success. Is there something else that may need to be done? The shorcut is running as an admin as well as in windows 7 comp mode.
Unable to Run RealTimeSync at Startup/Login Windows 10
Apparently on Windows 10 it does not show an icon in the taskbar however it shows as a process running. I just tested it with a file to sync to a network drive and worked.I recently upgraded from Windows 7 Pro to Windows 10 Pro. I had a shortcut running in the Startup folder to allow RealTimeSync to run at start up. Worked fine on Windwos 7 Pro. However after upgrading unable to have this start automatically. I even tried to make a scheduled task with no success. Is there something else that may need to be done? The shorcut is running as an admin as well as in windows 7 comp mode.
Thanksmharris612
I suspect the icon is hidden from the notification area until shown manually for the first time, just like on Windows 7.Apparently on Windows 10 it does not show an icon in the taskbar however it shows as a process running. I just tested it with a file to sync to a network drive and worked.mharris612
