I recently started using RealTimeSync to sync 2 drives automatically. After I started using this MS Word program opens up automatically after closing a Word document. The only way I can keep Word closed is when I go to Task Manager and "End Task" for Word. The next time I open and close a Word doc, then the loop starts again.
Has anyone else had this problem? If so, then how did you fix it?
MS Word reopens after closing
