I just installed FFS and after several trials I still cannot properly handle this.
The only way I can do it is to select one level below the directory (symlink) I want,
and un-select all except the one I want, then the line becomes yellow.
I doubt very much that's the way it was supposed to work.
Of course I checked "Include symbolic links" - "Direct" in the Comparison tab.
I thought that "Direct" meant copying a symlink as a simlink.
Thanks.
update/mirror a symlink to a directory
