Files didn't get synct because of changin both sides.
rocky112
Hello.
*First of all, I will give you an overview over my configuration.
I got a WORKSTATION, witch syncs via FreeFileSync to a local NAS (home1).
This NAS (home1) syncs via an other software over the internet to an other NAS (home).
Because I have to change files from my second home several times.*
My problem is now following.
If I finished work in home1, I start an sync via FreeFileSync from my WORKSTATION to my NAS (home1) [works fine]. After that the NAS (home1) sync it to NAS (home) via internet and here I work along on the files.
Over night NAS (home) sync the edited files to NAS (home1). At the next morning I start my WORKSTATION in home1 an get the Error code, that the files can not be copied, because both sides has been chanced since the last sync.
The problem is, that I just want that the program just overwrite the older files. Is there a way to change this option?
Can you help me please? THANK YOU!
