Use of starce with Freefilesync (Linux)
rabjo
Can you help please, I'm at a loss to understand how to replace the COMMAND_TO_TRACE with something sensible, surely it can't be freefilesync?
I’m getting a file copy error, FFS first creates a temp file 0 bytes then Errors 22.
Yes I can use Nautilus to copy files across to the other server with no problem.
How do I use strace within FFS?
Many thanks
