New to FreeFileSync.
Using MIRROR Sync.
Would like to keep empty folders in the mirror sync'ed backup as well.
e.g. If there is D:\Downloads\Best Files folder but it is empty then create that empty folder in the backup mirror drive as well
Doesn't appear to do it with the default settings. How can this be done, or did I just miss them when I looked?
Thanks!
Sync (Mirror) blank folders as well?
