Running Linux Mint 19 (Tara). Downloaded FFS vers 10.3 and unpacked the tarball into directory /usr/local/src/FreeFileSync
There is no Makefile that I can see, so I can't just do a make install.
When I just run the executable from the directory created by unpacking the tarball it works fine.
But when I copy the executable to /usr/local/bin (where it truly belongs) and run that version of the executable, FFS warns me that it cannot find the resources file under /usr/local/share
Are there proper steps I should take take to install FFS in its proper location?
pgmer6809
Vers 10.3 Install to /usr/local
