FFS 10.4 does pretty much everything one could ask for but there is always someone...
When using versioning you have three options: Replace, Time Stamp (folder), and Time Stamp (file) which work well, but using the 'Time Stamp" options also include the time. What if you only want a date? I tried using the following custom user defined folder "Z:\$_Revisions\%date% which works just fine BUT the option to limit the file versions is grayed out. Maybe there should be another versioning option: Date Stamp (folder) which of course would only include the date as yyyy-mm-dd. Adding the ability to limit versions was a welcome addition and adding this option would add a little more flexibility.
Thanks Zenju for an incredibly useful utility. I was more thank happy to donate.
New naming convention for Versioning
