Fisrt time usage
usawinters
Hi, thank you very much for the tool to the author. I have a question: during windows installation & first startup it tried to establish external connection to different hosts. I will appreciate it very much if you could clarify the reason behind such connections? If these connections blocked - the tool does not work.
During installation it accesses the internet to show an advertisement, during first start it checks if FFS is up to date. What you you mean with "tool does not work"?
usawinters
Thank you very much for a quick reply.
I press button "New" and nothing is happening.
"New" just creates an empty default configuration, like the "new" button in word processing software.
