I am probably an idiot for even asking this: I have setup batch jobs, and created schedueled tasks for these. But when i run the task as you do in the tutorial videos, I don't get any status of the copy job as you do in your tutorial video. I've checked the "hidden" taskbar icons as well, nothing there.
Is there anything I need to tick on to get this realtime synchronization status window?
Hi kalthor
I found your query while looking for an answer to the same problem - and I also found this answer
viewtopic.php?f=8&t=2476&p=17060#p17060
It seems you need to amend the scheduled task to "run only when user is logged on" - it worked for me :)
Thanks mcnash!
