create a dummy directory on another drive use it for source (it's empty folder)
right side = folder or drive to move (put in your filters) like *.mp3 | *.flac | *.ape
select mirror
in option select replace instead of recyclebin
put the folder where you want files moved
detect moves should be check, mine was by default
Finally figured out a way to MOVE FILES by filter
