2008 server Volume shadow Copy
theta
I have the donation copy and trying to run 64bit on windows 2008 server. I need to use shadow copy.
I check the box for locked files. I get an error that can load DLL shadow_server2003_x64.dll
Unfortunately the current codegen is broken for 64-bit Vista/Server 2008 due to automatically generating AVX2 instructions that are understood by later OSs, but lead to crashes/hangs on Vista. Usually and for this reason the launcher automatically picks the 32-bit FFS version, however VSS does not support WOW64.
