Hey,
I'm trying to copy items from the left side to right side but I want it so if the item is gone/deleted from the right side then it does not try and copy it again.
I tried using mirror-sync with the "Detect moved files" set to on, I then do the sync, delete the file on the right side, do the sync again, then it still wants to copy that same file again.
I'v also got time-span set to 5-days if that changes anything.
-thanks
Remember moved/synced files (for when right side is gone)?
