I just udpated from 9.3 to 10.5 on a Windows 7 Pro system I use to Real Time Sync a number of project files between offices. After I restarted I got a message box stating "A folder input field is empty." which I closed (my only option) and then I had to select folders to watch on either end of the sync for all 50ish of my projects.
My question is this: am I going to have to set which folders to monitor each time my server restarts, or did I just have to do it this once because of the update? I'm seriously hoping for the latter.
Any info would be appreciated, thanks in advance!
Real Time Sync Issue After Update to 10.5
Really? Nothing?
