Crash when synching User-Registry files on Windows 10
sfamix
I use FreeFileSync, elevated as Admin, running on Win10, in order to sync the User profiles of this machine from the old harddisk to a new SSD (SSD migration). All works fine, except when copying Windows Registry files. The files in question are:
*\NTUSER.DAT
*\ntuser.dat.LOG1
*\ntuser.dat.LOG2
*\AppData\Local\Microsoft\Windows\UsrClass.dat
*\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
*\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
Note: The last three entries are not available in every user folder, so preceeding paths may vary.
I have "Shadowcopy" set to ON.
The Prefs are set to also copy user-permissions and attributes, not to do the safe-copy, and to copy links "as-is" (not follow path).
During the synch-process I get an error for each of these files. The typical error message is:
The file
"C:\Program Files\FreeFileSync\GLOBALROOT\Device\HarddiskVolumeShadowCopy11\Users\Administrator\NTUSER.DAT" can not be copied to
"L:\Users\Administrator\NTUSER.DAT".
Errorcode 3: System can not find given path. (CopyFileEx)
(roughly translated from German)
After this I get a crash.
I will send some crashdumps and the complete error-log using your Sourceforge email address, referencing this post.
There are two different issues here:
That's a problem during VSS path generation. It has been fixed in the current beta:
[404, Invalid URL: http://www.mediafire.com/download/dl98vgenv6w27du/FreeFileSync_7.7_beta_Windows_Setup.exe]
The crash is happening in the DLL "C:\Windows\System32\vstmididrv.dll", might be a Windows 10 driver bug. I'm also seeing "C:\Program Files (x86)\Emsisoft Anti-Malware\a2hooks64.dll" entries. Depending on the quality of the AV software such hooks have the potential to let crash applications crash, so this is something to keep in mind.
sfamix
This is interesting! "C:\Windows\System32\vstmididrv.dll" is also causing crashes with other programs. As it seems, FreeFileSync (or Windows itself, I had to switch system sound off because of crashes) wants to play some sound and this driver interferes. I will uninstall that software. I think it's the OpenSource GM-MIDI driver, that is used for legacy DOS games under DOS-Box.
Thanks for checking out!
sfamix
Just wanted to give clearance: The beta works great, so far. And yes, the crash was seperate and based on the *vstmididrv.dll*, which is a part of the *vstmidi.exe* distribution (alternate GM-MIDI synth). I had to uninstall that package and now all the sounds work fine on my system, including the ones of FreeFileSync. This was causing the crash.
