How do I recover a hidden configuration file?
Grannyb
I wanted to rename a configuration file. I couldn't find a 'rename' button, so I right-clicked, but only saw a 'Hide configuration Del' option.
Before I could think it through, I'd left-clicked on that, and it was gone!
Can I get it back? I figured it would be a simple matter of 'unhiding' it, but I can't find a way of doing it.
bgstack15
The file was not removed from your hard disk. It was only removed from the MRU list (most recently used; programming concept). If you know where the file is, you can just go open it with FreeFileSync and perform the sync again.
The files tend to have a .ffs_gui extension.
