Hello
I have a problem, since 2 days it creates RecycleBin.641b.ffs_tmp folder which I can not delete anymore.
Does anyone know the problem how can I fix this?
And how can I delete the folders?
The folders are created in OneDrive Folder.
I have Windows 10
FreeFileSync 10.7
Build: 12/12/2018 Unicode x64
donate Version
Kind regards
Jürgen
RecycleBin.641b.ffs_tmp Folder
Jürgen!
I have similar problems. I resolved it by Ignorieren/Ignore or Alle ignorieren/Ignore all. Than sometimes I had to erase the RecycleBin..... of FFS manually. It can go quite deep in the file-tree.
The software has some problems, I'll report a bug also.
Look also at the answer in Sync gets stuck right before completion.
regards Janos
regards Janos
Hello Janos
I could not delete the files manually, only now I have found a way how it works without problems, hope that now no new RecycleBin.641b.ffs_tmp folder will be created.
One must with a ZIP program the file pack and in the attitudes the hook put (files after the archiving delete) then the files are deleted without problems.
regards Jürgen
regards Jürgen
A RecycleBin[xxx].ffs_tmp folder will always be created if files are to be recycled in an FFS sync.
However, it should also be removed when FFS terminates correctly.
See viewtopic.php?t=5712&p=19021#p18971
