[Feature-Request] Postpone scan of blocked Folder pairs
Sorontik
Hi
I just noticed that FFS doesn't start comparing any Folder-pair if just one is blocked, at all.
I suggest to postpone the scan of blocked Folder pairs and start by scanning the others until only blocked folder-pairs are left and then periodically check for any of them becoming unblocked. This one can then be blocked and scanned, returning to the wait/check loop afterwards until eventually all Folders have been scanned.
Maybe, depending on the implementation details, it is also possible to allow the two Folders of one Pair to be scanned at different times and compared as soon as both have been scanned.
What do you think about this?
best regards
Soro
