Greetings all!
So, I used to use version 9.6 on my Windows 10x64 machine, and everything worked fine. I had created and saved batch jobs that mirrored my desktop folder and my entire D drive to my external backup drive, and I had scheduled them to run on login.
It worked fine, every time I turned on my machine, it would pop up and show how it was comparing and backing up my data.
Then, I downloaded and upgraded to version 10.7, and everything stopped working.
I deleted the old batch jobs and scheduled tasks, and created new, identical ones.
Nothing happens.
I can manually run the backup through the program interface, but the scheduled run at login just does not work at all.
I just now downloaded 10.7 and tried again, and it doesn't work either.
HELP!!!!
What am I doing wrong? It used to work flawlessly...
Upgraded to latest version, sync no longer working
Anyone?
