Automatic backup with timestamp ?
ricoh83
Hello everyone,
I've been able to successfully backup folders automatically by adding BatchRun.ffs_real in the registry. At that time it shows the following status
However, the same method does not work automatically in case of timestamps. At that time it shows the following status
I think it is expecting a folder named 2019-01-04 to appear inside H:\New Folder before it starts the backup process. Ticking the ignore errors check box does not help. Do you think if the program(RealTimeSync) sees the target path as H:\New Folder\%timestamp% rather than the pic above that would solve the problem ?
Best regards,
Ricoh
