I'll just describe what happened: I connected a new, 1TB Seagate Backup Plus USB drive to an Optiplex GX620 running XUbuntu 18.04, created 7 backup folders in its root directory and set up FreeFileSync 10.7 Build 12/12/2018 - Unicode x64 to mirror 5 local HDD folders and 2 network folders. I stopped the backup 2 or 3 times and then re-ran it when I'd done whatever I needed to do, and since it was taking a long time, (to be expected backing up 133,000 files/124.3 GB of data), I set it up to shut down when complete.
The next morning, when I went to view the USB drive's contents (in Thunar 1.6.10), 3 of the folders were shown as empty. When I tried running FreeFileSync again, pressing the "Compare" button resulted in errors stating that FFS locks could not be created in those 3 folders. Having had something similar happen in the past, I opened an xfce4-terminal (0.8.7.4) window, "changed" to the USB drive and found that the backup appeared to have been "successful" (the folders were not empty), but that in each folder (and in 2 subfolders of another folder), there were damaged "files" named like FreeFileSync lock files. Where I would normally expect ls -l to give something like:
lrwxrwxrwx 1 user group 42 Jun 4 2018 [name].lock
...everything but the [filespec] was show with question marks, thus:
?????????? ?? ? ? ? ? ? [name].lock
Even as root, the system would not let me rename, move or delete these "files" (I tried rm & rmdir), or change their attributes or owners. That may be a XUbuntu bug, and fsck was also unable to even recognize that there was something wrong with them, but FreeFileSync was unable to create locks in those directories. I'm sorry I didn't record all the error messages. I even tried moving all the valid files and directories to other folders and deleting the folders with the damaged lock files, without success. There was nothing I found I could do in XUbuntu that would fix or delete those files, and I don't have a directory editor for XUbuntu...
What I finally did was boot into Windows 7 Professional and use Windows' file manager tools to repair the drive. The reason I'm posting this here is that there appears to be a problem with what FreeFileSync does with locks it creates when it's stopped while comparing folders for synchronization.
Damaged Lock Files in XUbuntu 18.04
This problem still exists in Ubuntu (Xubuntu) 18.04. Here's the result of ls -l in an affected folder:
root@OptiPlex780:/media/kent/3F226CEF1B70943F/Backup_2/Everyone# ls -l
ls: cannot access 'sync.ffs_lock': Input/output error
total 156
drwxrwxrwx 1 user user 4096 Jun 24 23:12 Hangul
drwxrwxrwx 1 user user 32768 Jul 2 09:08 Humor
drwxrwxrwx 1 user user 16384 Jun 24 23:13 Info
drwxrwxrwx 1 user user 4096 Jun 24 23:13 'Linksys WMP11 v1'
drwxrwxrwx 1 user user 4096 Jul 2 09:08 People
drwxrwxrwx 1 user user 8192 Jun 25 07:19 PowerPoint
drwxrwxrwx 1 user user 4096 Jun 24 23:13 Sayings
drwxrwxrwx 1 user user 20480 Jun 24 23:13 Sound
drwxrwxrwx 1 user user 12288 Jun 24 23:13 Stationery
-????????? ? ? ? ? ? sync.ffs_lock
drwxrwxrwx 1 user user 4096 Jun 24 23:13 Text
drwxrwxrwx 1 user user 4096 Jun 24 23:13 'Transportation & Maps'
drwxrwxrwx 1 user user 4096 Jun 24 23:15 Videos
total 156
