am using AWS new service SFTP Transfer (backend is S3) for data sync, FFS 10.3 and 5 previous working ok though the comparison (list objects in S3) take long time, but since I upgrade to 10.7, FFS not able to list the S3 bucket, error message:
Cannot read directory "sftp://xxxxxxx.server.transfer.us-east-1.amazonaws.com".
LIBSSH2_ERROR_SFTP_PROTOCOL: SFTP Protocol Error - LIBSSH2_FX_FAILURE [libssh2_sftp_readdir]
I tried FFS10.8 not work neither. But if I switch back to FFS10.3 it's working, anything change on this?
Thanks.
AWS SFTP Transfer not work with FFS 10.7 and 10.8
I'm not aware of a change that would have affected SFTP folder traversal between these versions other than library updates (libssh2, openssl).
Hi Zenju,
If that meant the problem could be solved on the SFTP server side? Thanks.
If you have some test login data for me, I can have a look what this difference in behavior is about.
Hi Zenju,
I create a test login to you and sent to the support email address, please help to check, thanks.
Thanks, simmy, I'm working on it.
Fixed! There were two issues:
1. The content of the "\blanche\test" subdirectory (containing 1000 files) was returned by AWS in a single SSH package, which libssh2 interpreted as corrupted. => threshold adapted
2. The SFTP folder picker was not able to navigate to the home directory "\blanche" because access to "/" is denied. => FFS folder picker now supports SFTP home directory + navigation beyond access-denied parent folders:
https://www.mediafire.com/file/adiii9l5pru67u5/FreeFileSync_10.9_%5BBeta%5D_Windows_Setup.exe
Thanks Zenju, tested the new version, the access denied access issue gone, but for the file comparison is still very slow and keep got interrupted, is it because of S3/SFTP return the files in block but no in single files cause the issue?
I tested ver 10.9 on my actually files, file size from hundreds KB to 30MB, format from text, csv to bmp, jpg, and long file name etc..
Thanks.
Thanks.
Not sure what you mean with "interrupted", but as regarding speed you may compare with another SFTP client to see if it's a server/connection problem or not.
