Google Drive Sync Help
AlexGiov
When I sync a local folder with a google drive folder I get an error aboud google drive files, how can I filter google files?
The error abuot the "Untitled document" google file:
Impossibile leggere il file "gdrive:\alexgiov.mail@gmail.com\test\Untitled document".
Il server ha restituito un errore:
"error": {
"errors": [
"domain": "global",
"reason": "fileNotDownloadable",
"message": "Only files with binary content can be downloaded. Use Export with Google Docs files.",
"locationType": "parameter",
"location": "alt"
"code": 403,
It seems all Google Docs files have 0 file size when listed in FreeFileSync. I'm not sure if it would be useful to automatically exclude them by FFS, even though they cannot be copied as normal files.
