Having run an extensive compare which took in excess of 24 hours I began a partial update sync and minimised the window a little later I checked to see progress and the program had stopped. The log simply shows one line saying error: stopped.
Is there anyway I can load in the compare results and re-start the sync process?
I'm using V10.8 on W10, however one of the sync drives in on an iMac.
Thanks for any advice.
Sudden stop
Non-problem.
The large blue down arrow in the sync window minimised both the sync window and the comparison window. Either at that time or a little later the comparison window closed altogether. At that point I raised this query. Later still I got a sync error message pop up and discovered that the sync process was in fact still running. when the job finished both windows opened up and no information had been lost.
Not sure if this was a glitch or a clunky way the progam minimises, either way no damage done.
