Hi Filesync team,
Many thanks for your efforts on FFS.But I have some problems when using it.FFS shows "cannot set directory" after comparing & "cannot copy file" after synchronizing and always jumps out "Error code 2--The system cannot find the file specified".I also attached the file with print-screen.Could you kinldy help it?Thanks!
Best,
Bob
Error Code 2
The error code description seems to suggest the user under which user credentials the FreeFileSync (FFS) task is run does not have write permission in D:\Users\Ian\Documents\Buddhism
