Today, in order to use FreeFileSync, i do some tests.
So, when i try to save more than 3 versioning (my max for my test), problems...
For instance, i ve this file :
- test.txt in the first repertory
I want three versions for versioning.
The first :
test.txt 2019-02-14 093833
The second :
test.txt 2019-02-14 093944
The last :
test.txt 2019-02-14 094057
I configure the max versioning for 3 versions and because of that it's impossible to save new file and modifications.
Do you have ideas for this problem ?
Thanks,
Herve
Versioning v.10.9
