Action on conflict files
Nono
I wonder if what I need is possible: I am synchronizing a computer and an USB key. I would like that, in case of a conflit on a file, freefilesync copies the computer version of the file on the usb key, with "conflict detected - computer version" at the end of the copied file name.
For example, if the file foo/bar.txt is in conflict, freefilesync copies the file bar.txt of the computer in the foo folder of the usb key and names it "bar - conflict detected - computer version.txt"
Is it possible?
thanks a lot!
markusoft
already there with versioning, but that brings to why I'm here
I would like ANOTHER option in versioning of DELETIONS
so ONE folder direction would be for Versions and the OTHER for DELETIONS
I would like to KNOW what files changed and what Files were deleted in two seperate folders as like
Versions
Deleted
Nono
Thank you for your reply!
I tried to use the versionning, but my version folder stays empty.
Besides, freefilesync copies a file in the version folder only if it is deleted, no?
I want that it copies the file in case of conflict.
Is it possible?
