I'm trying to Mirror some "Program Files" folders from one PC to another (Win10 -> Win8.1).
I'm signed in as an admin user on both PCs. A Homegroup is set up, I can manually browse or change Program Files on the other PC in Explorer (including writing files & creating subdirs).
But FFS can't:
- in non-admin mode, it gets file access errors (Code 5), eg. creating subdirectories.
- in admin mode, it asks me for my Network Credentials (user/pass) to access the other PC path at all. Why, when I can access them manually without credentials?
Note I'm using \\[pc name]\ type patths, so I don't have to map network drives (the other PC is rarely connected). Is that the problem?
FFS asking for network credentials to access Homegroup (admin)?
Because an account must be provided, either implicitely or explicitely:
- create an account with same name and password on both machine, give them the permissions needed and use it to login (implicit)
- map the remote destination with a remote user/password, you can use just "net use \\remotepc\remoteshare /user:username password" without a disk letter name (explicit).
Give it a try (never used Win8/10, but on Seven it's like that)
