Problem to compile source code with openSuSE 15.0
M158m15
hello community,
to compile the souce code of FreeFileSync was not possible for me. What did I make wrong ? What does not work with SuSE 15.0 ? First I did download the newest version of FFS 10.9. Then I did extract it to my download directory.
 srv15:/home/han/Downloads/FreeFileSync/Source # cat /etc/os-release
NAME="openSUSE Leap"
VERSION="15.0"
Then I tried to compile it. But it does not work at all. Does anybody know what I made wrong ?
srv15:/home/han/Downloads/FreeFileSync/Source # ll
insgesamt 2432
-rw-r--r-- 1 han users    7834 17. Feb 11:51 Bugs.txt
-rwxr-xr-x 1 han users  109264 10. Feb 10:33 Changelog.txt
drwxr-xr-x 4 han users    4096 10. Feb 10:33 FreeFileSync
-rw-r--r-- 1 han users 2302331  2. Mär 19:22 FreeFileSync_10.9_Source.zip
-rwxr-xr-x 1 han users   41834 10. Feb 10:33 License.txt
drwxr-xr-x 2 han users    4096 10. Feb 10:33 wx+
drwxr-xr-x 3 han users    4096 10. Feb 10:33 xBRZ
drwxr-xr-x 2 han users    4096 10. Feb 10:33 zen
drwxr-xr-x 3 han users    4096 10. Feb 10:33 zenXml
try with "make"
srv15:/home/han/Downloads/FreeFileSync/Source/FreeFileSync/Source # make
mkdir -p /tmp/FreeFileSync_x86_64_Make/ffs/src/base/
g++ -std=c++17 -pipe -DWXINTL_NO_GETTEXT_MACRO -DLIBSSH2_OPENSSL -I../.. -I../../zenXml -include "zen/i18n.h" -include "zen/warn_static.h" -Wall -Wfatal-errors -Wmissing-include-dirs -Wswitch-enum -Wcast-align -Wshadow -Wnon-virtual-dtor -O3 -DNDEBUG `wx-config --cxxflags --debug=no` -pthread `pkg-config --cflags openssl` `pkg-config --cflags libcurl` `pkg-config --cflags libssh2` `pkg-config --cflags gtk+-2.0` -isystem/usr/include/gtk-2.0 -c base/algorithm.cpp -o /tmp/FreeFileSync_x86_64_Make/ffs/src/base/algorithm.cpp.o
/bin/sh: wx-config: Kommando nicht gefunden.
Package openssl was not found in the pkg-config search path.
Perhaps you should add the directory containing `openssl.pc'
to the PKG_CONFIG_PATH environment variable
No package 'openssl' found
Package libcurl was not found in the pkg-config search path.
Perhaps you should add the directory containing `libcurl.pc'
No package 'libcurl' found
Package libssh2 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libssh2.pc'
No package 'libssh2' found
Package gtk+-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gtk+-2.0.pc'
No package 'gtk+-2.0' found
cc1plus: warning: /usr/include/gtk-2.0: Datei oder Verzeichnis nicht gefunden [-Wmissing-include-dirs]
In file included from base/algorithm.h:13:0,
                 from base/algorithm.cpp:7:
base/process_xml.h:10:10: fatal error: wx/gdicmn.h: Datei oder Verzeichnis nicht gefunden
 #include <wx/gdicmn.h>
compilation terminated.
make: *** [Makefile:124: /tmp/FreeFileSync_x86_64_Make/ffs/src/base/algorithm.cpp.o] Fehler 1
bgstack15
The obvious errors I see include
And the similar ones.
To compile something from source code, you need to provide the development headers of the dependencies. Obviously here, the dependencies include openssl and libcurl. I don't know how openSuSE names their packages, and distrowatch doesn't list the development packages (link) so you will want to check for openssl-dev or openssl-devel (or possibly even libssl-dev) in your package manager. wx-config comes from a wxGTK-devel package or similar.
For my complete buildrequires on Fedora:
BuildRequires: boost-devel
BuildRequires: compat-wxGTK3-gtk2-devel
BuildRequires: desktop-file-utils
BuildRequires: gcc-c++
BuildRequires: ImageMagick
BuildRequires: pkgconfig(gtk+-2.0)
BuildRequires: pkgconfig(libselinux)
BuildRequires: pkgconfig(zlib)
BuildRequires: libcurl-devel %{min_libcurl}
BuildRequires: libssh2-devel %{min_libssh2}
BuildRequires: wxGTK-devel
BuildRequires: %{scl_buildreq}
BuildRequires: openssl-%{name}-devel %{min_openssl}
BuildRequires: openssl-devel
Source: my own Centos/Fedora rpm spec
I confess I don't quite understand the pkgconfig() components. I think basically it is an attribute of whichever is the development header package of the named package, i.e., the zlib-devel rpm has an attribute: "Provides: pkgconfig(zlib)." The names in Fedora are fairly straightforward and this should get you on your way to finding the right packages in openSuSE.
wx-config acts similar to pkgconf --libs, and I'm pretty sure is included in Fedora's wxGTK-devel.
Ah-ha! I found an openSUSE rpm spec file which should be incredibly useful here, albeit it was for FreeFileSync 10.7 so you'll need to add the openssl-dev and libssh2-dev and libcurl-dev.
M158m15
hello bgstack15
thank you so much for your help.
I did follow your suggest and downloaded from the suse repositories the FFS rpm file.
the installation of this rpm-file on my opensuse 15.0 was successful.
just for fun -- the compilation of the source code is still not working, but the amount of errors
did decrease enormous.
In file included from base/../fs/abstract.h:13:0,
                 from base/structures.h:14,
                 from base/file_hierarchy.h:19,
                 from base/algorithm.h:11,
../../zen/serialize.h:35:45: error: ‘byte’ is not a member of ‘std’
     using value_type     = std::vector<std::byte>::value_type;
compilation terminated due to -Wfatal-errors.
best regards
M158m15
bgstack15
I had a vaguely similar issue on Devuan regarding the "(something) is not a member of `std`" error. I think it has something to do with the way that distro packaged the C++ standard libraries. Check out https://stackoverflow.com/a/52570365/3569534.
Relevant bits, in case the link dies:
Add #include <cstddef> into serialize.h and ring_buffer.h
cd ../../zen/
grep -q -F '<cstddef>' serialize.h || sed -i '1s/^/#include <cstddef>\n/' serialize.h
grep -q -F '<cstddef>' ring_buffer.h || sed -i '1s/^/#include <cstddef>\n/' ring_buffer.h
