Can I keep delete files in Source and Target folder respective?
testsoft
My case is using FFS to synchronise data between 2 PCs. I want to keep the deleted files in the PCs respective.
PC1Dir
|--Dir1
| |--file1
| |--file2
| |--Dir2
| |--file3
|--Dir3
| |--file3
|--oldVer <---- (exclude in [Filter] option)
|--[YYYY-MM-DD hhmmss]
| |--Dir1
| |--file1
|--Dir1
|--Dir2
|--file3
PC2Dir
|--Dir1
| |--file1
| |--file2
| |--Dir2
| |--file3
|--Dir3
| |--file3
| |--Dir1
| |--file2
|--Dir1
|--Dir2
|--file4
However, the option inside [Delete files -- Versioning] is keep all deleted files to one side only.
Any [Macros] can be use in the option [Delete files -- Versioning -- Move files to a user-defined folder] for this case?
If not, will FFS add this [Macros]?
eg. [RespetiveFolder] represent the LeftSideFolder or RightSideFolder due to the items delete/move in the respective side.
I am looking for your help. Thank you very much!
