Move files instead of deleting them to different sites
leyHKV
the ffs program has the option of moving the files to a folder instead of deleting them (when applicable) but it can only be moved to a folder of the two parts, there is no possibility to move the files from one side to a different folder and those from the other side to another or eliminate those on one side and move those on the other, would that function be possible? that is to say: distinguish what to do with the files according to whether they have to be eliminated from one side or another
clipper1
Generally, moved files will not be deleted. And instead of files getting deleted you can specify any one folder to move them to: Synchronization - Versioning - Specify destination folder
https://freefilesync.org/manual.php?topic=versioning
I'm not sure what happens in a conflict case. If for some reason you need two different folders or want to avoid conflicts you might need to sync two times with different directions. I hope I could help somehow.
Cheers clipper
