Include/Exclude Filter, recurse subdirectories
ferblaha
is there a way to indicate, in the include/exclude filters, to recurse subdirectories with a certain filter?
Thank you
Fernando
ferblaha
Hello Zenju, thank you. I've already visited that page and checked the syntax.
What I'm not making work is the following:
Exclude filter: *
*Include filter: a sort of directories, with all it's contentes (files and subdirs).*
What I'm trying to do is sync in a machine SOME directories of a certain path. The reason why I'm using the exclude filter = "*" and edit the include paths, is because there are lots of dirs to exclude, and only a few to include. I cant make work to include a directory and all its contents (files and subdirectories).
Please tell me whats the correct way to do this.
Just use an include filter for the items you want and leave the exclude filter empty.
ferblaha
Hi Zenju,
yes, that's what I'm trying to do. But I cannot make the include filter to include all files and subdirectories in a path, unless I write a line for each subdir... Is it possible to recurse subdirectories or not?
Thank you
Can you give a specific example what you are trying to do?
ferblaha
Yes of course, thank you.
I have a directory structure like this:
SFTP:\_SHARED\Folder 1\ files and subfolders
SFTP:\_SHARED\Folder 2\ files and subfolders
SFTP:\_SHARED\Folder 3\ files and subfolders
SFTP:\_SHARED\Folder n\ files and subfolders
In a particular machine, I want to sync, i.e, Folder 1 and Folder 2 only (with all its contents).
For that, because there are n folders in the path "_shared" , and n is much bigger than 2 (the folders I want to sync), I decided to edit the filters like:
Exclude: *
Include: \Folder 1\* ;  \Folder 2\*
With SFTP:\_SHARED as the root path of the sync configuration.
But this is not working for some reason, it does not sync all the contents of the two mentioned folders...
Am I doing something wrong?
Thank you again Zenju
Fernando
Exclude: *
Fernandoferblaha
The filter setup looks correct except for the exclude filter which should be empty. (Include and exclude filters are AND-related, not OR)
ferblaha
Ohhh ok Zenju!
I will try leaving the exclude filter empty... sadly I can't try until monday...
Thank you!
Happy holidays!
