When I first use the Batch file, I get an error of multiple bases being used and to create a filter (I have never really understood that).
When I go to FreeFileSynch and then I do the exact same Two-Way, it does it without any errors.
I then run the Two-Way again using the batch and now it too gives me no error
I synchronize 4 folders as follows:
Listed from the Top down:
S:\ <-> O:\
S:\ <-> P:\
S:\ <-> Q:\
S:\ <-> R:\
What is the problem and what should I do?
Strange error
