Sync two remote PCs
I have a PC at my office and one at my residence. Both contain many identical files and folders. Will FFS allow me to do this? For example: I edit a file on my home PC and it's automatically updated on my work PC. Or, do I have to do that manually each time I edit a file?
Hi, I'm new to FreeFileSync, but yes, you can use the 'two way' option and google drive for both PC's
Home PC > {Google Drive}
{Google Drive} > Work PC
..and vice versa.
You can setup an auto sync so that it runs at the end of your office hours, or hourly, or manually when you feel the need...depending on your needs. This is really handy, as you can also view/edit the same files on your smartphone, and once you get home or to work, those updates will be ready post syncing.
..and vice versa.
