I have two objectives and the first is to store my important files in the cloud. That is fairly easy but I want to use pCloud in particular and I also want to sync those files across two very similar computers. I have tried the available pCloud sync option but there are issues and it is not user friendly hence now looking to use FFS.
pCloud has it's folders setup on your computer like other similar cloud options. I am thinking same folder setup on both computers and use FFS to sync to those folders two way. I would appreciate any comments or feedback from members of this forum or FFS. Thanks.
Cloud sync using pCloud plus 2 computers
