Hi, i sync files to mutliple servers accross the world. Right now i use a file which is called "last_sync.txt" and check with my monitoring system if the "last_sync.txt" file was not modified since two days ago.
My problem is that the "last_sync.txt" file gets right now sync at the beginning of sync task which does then not reflect the truth of the sync status if it will cancel in the middle of the sync task. Would it be possible to add a function where i could define that the "last_sync.txt" file gets always synced as the latest file?
Thank you & Regards
T.O.C
Feature Request: some file should synced at the end
You could solve this using multiple folder pairs, with the last pair syncing only last_sync.txt.
